BrokenBiker
- Newport, South Wales
so basic ie standard run of the mill inverters generally can use only standard run of the mill rods, which is all I would use anyways, thanks
you will be able to run 6013 and 7018 no problem with a bog standard inverter, may need a bit more punch for 6011 but i think 6010 are ok to run, or possibly the other way round.
to be fair, as you werent sure what a cellulose rod was, i doubt you will need to run them, they arent cheap to buy and quite specific rods really with fast freezing slag.
i tend not to weld downhill if i can avoid it but if i have to i find 6013 will do it ok with a bit more rod angle to force the slag back a bit, maybe its me being crap though and not traveling fast enough
