"over here" I see Lincoln & Miller units IIRC about 250 amps.What output of amps can Inverter welders go to on a 240v supply?
Can you clarify what you actually want to know?What output of amps can Inverter welders go to on a 240v supply?
My 200 amp tig inverter will run 4mm 6013 rods all day long on a 13 amp supply.If limited to the standard mains socket of 240v 13amp plug. I was curious of what an inverterter could burn in term of rod diam. For example When using my 160amp stick welder on 4mm rods I had to use a 30amp supply
I don't actually know what size rods an inverter can burn while using ONLY standard 240AC without blowing plug on a 13amp plug.
welders have come a long way since 1982...realistically, ignoring the TIG completely, between my mig and stick welding i can weld from 0.8mm to 10mm+ on a 13amp supply and my welders arent expensive units eitherI got my SIP stick welder in 1982. I don't know if that is relevant
				I have a 250A single phase inverter stick welder.What output of amps can Inverter welders go to on a 240v supply?
				Generally over here there's 3 phase (220 volt x 3 or 415 volt, but that depends on how the machine itself is wired internally I believe) or Single Phase termed as 240 volt, which is most homes.Another important thing to note is that there are also 240V Three phase machines.
I think no one asked if the op ask for either single or three phase units
Same here in Italy.Generally over here there's 3 phase (220 volt x 3 or 415 volt, but that depends on how the machine itself is wired internally I believe) or Single Phase termed as 240 volt, which is most homes.
Houses with 3 phase are rare in the UK....
