Which Metal can I use for wheel spacers?
My car has upgraded front brakes and calipers.
And to centralise the brake discs in the calipers the previous owner has fitted steel washers, approx 3/4mm thick, fitted behind the brake discs, in between the hub and the disc.
The washers are inserted over each wheel stud prior to fitting the brake discs.
Although, the washers are not causing any problems, I would much prefer custom made spacers fitted, of the required thickness and ideally of same diameter of the hub and the internal dimensions of the discs.
My first thought was to use 3/4mm thick mild steel cut to shape with holes drill to thread over wheel studs.
However, I've been wondering whether I could use a metal alloy product, as such items are readily available for purchase, with holes for studs per drilled.
These alloy wheels spacers, which are machined to shape and not cast, are specifically designed to be used between the car wheel and hub and not in between the brake discs and hub.
So, would an alloy wheel spacer be suitable, thinking of heat generated during braking ?
Any ideas ?
Any ideas ?
