Hello all, newbie here. Im currently working on a bmw e36 coupe and Im looking for advice on how to treat the metal before/after welding and fitment.
I got 3 spray guns, each for stone chip, paint, epoxy primer
Im kinda stuck on how to apply all my coats efficiently, since I cant do big area at once, i gotta go step by step like maybe one wheel arch, then drivers side floor on front and etc??
Also, do i need to sand between each of those chemcials, If yes then how much etc?
(Sorry this is my first project and i wanna do it right)
So the plan so far is :
1. Wire wheels on grinder, drill, air tools with wire wheels. Clean as much as i can.
2. Clean surface with "nitros thinner" Im not sure If thats what its called in english but its strong solvent or paint thinner basically
3. Using florin rs rust converter on all the rust spots i cant cut or get out. (I know this is the thing i have to let cure 100% before adding anything)
4. Then epoxy primer atleast 2coats, maybe 10min between coats?
5. Havent figured out how long i should let it cure but next i should cover welds with seam sealer
6. Another coat of epoxy
7. Stonechip (wheel Wells and underside) Im also painting body behind the front fenders so no point on Putting the chip there
8. Paint (maybe 2-3 coats?)
9. Maybe bitumen to the Underside, not sure
10. And lastly i have this aerosol body cavity wax. Its like an oil/oilish Goo. Gonna use this as well to the Underside, inside Rockers etc
My main confusion is sanding and dry time.
Do i need to sand between each step? (not coat)
My plan is to carry this out with wet to wet method, meaning the previous coat has not fully cured yet. Im using chamalaeon 455 epoxy and on the can it says its paintable after 45min.
Im just not sure If the wet to wet method is the best approach and when and how much do i need to sand If at all. I know sanding is needed when your not doing wet to wet.
Main goal is to get the Maximum best rust and moisture protection.
Since Im not painting the body but only the Underside, wheel Wells, behind the front fenders (non visible) places, the visual aspect is not really important.
Any tips?
Like i mentioned above that its my first project, i wanna do it right
So i think i need details like sanding, grit level, dry time or should i not go with wet to wet at all.
Whats the most efficient way to work since i cant really do big area at once but then again mixing 50ml paint for the gun seems silly too haha.
How have you guys done something like this?
Any tips?
