Wendelspanswick
I am after some advice from a Sparky, I want to add some sockets into the ring circuit in my workshop. The current wiring is in 4mm singles in steel conduit and square containment, fed from a 32amp cartridge fuse. Where I want to add my sockets I am going to have to cut into the existing ring (it is going to be awkward to draw in the new singles back to an existing outlet). The joint will be in the square containment.
My question is can I use yellow crimp connectors with the proper ratchet crimp tool to splice the 4mm together or do I have to use terminal blocks (which I loathe).
Cheers in advance.
Cheers in advance.
