Adjustable Vice Pillar Lift
I look at the “ show us you vice bench thread” and drool.
My situation is, I purchased a 3 bed property a while back with a fair size amount of gardens front and back.
As my physical health allows, I'm renovating, no external work shop or garage, that plan eventually is either block build or storage containers.
Meanwhile I desperately need a vice to be set up semi permanently on a rear concrete patio area.
I don't have the budget to buy an adjustable pillar vice, it's going to have to be on the cheap DIY but practical.
I have to sit and stand when working constantly, a B&D bench can only be used for so much, I require something more heavy duty I can sit or stand at.
Vice thread makes me want so much, been thinking about it.
My idea would be to purchase an Acrow prop' 0, mount the bottom to a 500x500x6mm steel plate for stability but bolted into concrete, the top plate the same dimensions, bolted through and mount a bench vice on that.
Would the 6mm thick steel plate take the rigours of a vice used not so much for weight, more for clamping and loosening things with a hammer, that type of thing.
Opinions please, would this work or is it to simple an idea?
Might make the top plate 1000mm (L) x500mm(W) x 6mm.
