not exactly welding but please bear with me, ive got a job at work that were upgrading the control system for, during the upgrade all the motors on the machine need to be replaced, we are using a siemens solution, the motors that siemens have spec'd arent really compatable with the gearboxes and equipment on site, an example is, one of the gearboxes on site has a flange fitting of 100mm pcd and the input shaft is 19mm keyed, the equivalent servo motor from siemens is 130pcd and 24mm shaft.
is there anyone out there that sells off the shelf adapter plates that woud do what i need it to? we'd also need shaft reducers aswell.
cheers scott
cheers scott
