pawsnizzy Forum Supporter Messages 925 Location Derbyshire, UK Dec 30, 2020 #1 Hi Guys/Gals, I've got a pipe (plastic) which has an OD of 34,5 - Is this a 32mm pipe? I need to fit a 90 deg bend to it but I don't know what type it needs to be either Any help appreciated Dave
B bricol Member Messages 6,760 Dec 30, 2020 #2 Sounds like it - and depending on material, compression, push-fit or solvent weld fittings - what's on the other end should give you a clue?
pawsnizzy Forum Supporter Messages 925 Location Derbyshire, UK Dec 30, 2020 #3 There's nothing on the other end, just a hose from a condesate pump
B bricol Member Messages 6,760 Dec 30, 2020 #4 Push fit or compression then - take it, or a small off-cut to local DIY shed and try for fit.
RWD3M Forum Supporter Messages 3,692 Location Wiltshire, UK Dec 30, 2020 #5 bricol said: Push fit or compression then - take it, or a small off-cut to local DIY shed and try for fit. Click to expand... Good advice, not all 32mm pipe fits all 32mm fittings!
pawsnizzy Forum Supporter Messages 925 Location Derbyshire, UK Dec 31, 2020 #6 Thanks Guys, Unfortunately can't remove it, got no offcuts and can't cut any off! Printed one off instead and it works a treat
