ProCage
Ok just a quick one (hopefully) got a new machine on the way Kemppi 2300, and I've been reading through the manual.. Bit confused on the ac balance range.
Ac balance States that it's from 0 to -50, factory settings -25%.
The fact it adds a % symbol in the manual after the 25 that confused me.
So is saying 0% to -50% EN?
0% is more EP, -50% is less EP.
normally if a welder says 30%-70% it's refering to the EN % of the AC wave?
So,
100 - % = EP%
I.e adds up to 100% for one cycle, right?
So what is the scale lol, because zero can not be full DCEP and going to half way so equal.
My guess is 0% is 50/50 and taking it down to -50 must be full DCEN... But that would also make no sense at all, as it wouldn't be AC then, so maybe 75% is -50%, jumping to some very big conclusions here lol
If that was true the range is from 75%EN to 50%EN
If it was that seems like an odd range to have, my other guess is that if you wanted to go the other end of the scale then you have to switch the leads round, because in theory at 50/50 balance it would weld the same in either plus or negative pole for work piece.
That would give you 75%EN To 50%EN Switch leads then 50%EN To 25%EN...
Are you meant to switch the leads on the front of the machine?
The manual seems a bit lost in translation lol MIght make complete sence when I recive the machine but at the moment bit confused.
Hopefully you can see my logic here and I'm not just being flat out 100% dumbass, I like to fully understand things so I won't rest till I know this answer haha
Cheers.
So,
100 - % = EP%
Cheers.
