johnakay Member Messages 1,772 Nov 18, 2012 #1 does the higher no mean finer grit on a ginding disc or is it lower? I bought some of this and it is a bit course. ABRASIVE DISCS 100mm X 16mm Grit 60 Last edited by a moderator: Nov 18, 2012
T tab Member Messages 156 Nov 18, 2012 #2 Yes, the higher the number the finer the grit, 60 is low and course
Hitch Moderator Staff member Messages 13,538 Location England Nov 18, 2012 #3 36 grit very coarse, 1200 grit very fine...... Same as sandpaper and other abrasives. You can get quite fine discs, the sort that fit on a backing pad. 100x16, is that the black hard disc type?
K KemppiFrog Member Messages 4,298 Location Aquitaine Nov 18, 2012 #4 Sounds like it. 16mm would be the diameter of the centre hole. But I would expect a third no. the thickness of the disc.
pedrobedro Man at Matalan Messages 13,116 Location CX near Chesterfield Nov 18, 2012 #5 They sound like fibre discs for a 4" grinder with backing pad. 60 grit is good for taking welds down and removing heavy rust.
johnakay Member Messages 1,772 Nov 18, 2012 #6 cheers chaps. yes sanding disc.I bought 50 cause it was cheap!
