I will preface this question by stating I am an inexperienced hobbyist wanting to learn. I work in IT and it's 30 years since I did my CDT Technology GCSE.
I've bought a second hand Sealey 355mm abrasive chop saw. I have been cutting 25mm box section steel on a 45 degree angle to make a welding cart. I have drawn up some plans so I know what length I need each side to be.
To ensure the frames are square I need to ensure that each of the opposite sides are of the same length and to be a better engineer I need to try and make my work match my plans.
I have made one frame but the issue I had was that despite cutting the first mitre, measuring up, marking my next cut and lining that up to a static blade edge each piece was not the same length by a couple of mm.
My question is am I missing a trick in how I am lining the work up to cut or should I be cutting my work slightly longer and grinding the two pieces to be the same/correct size? The saw table doesn't have any markings to work to. Any advice would be gratefully received.
