Abracs Poly Abrasive Disc
Attach this poly abrasive disc to your angle grinder tool to remove surface imperfection from your material. The Abracs disc can be used on a wide range of materials such as metal, concrete, stainless steel and aluminium. The synthetic resin coating clings to rust, paint and other contaminants...
I bought the Abracs 115mm disc to use with my 115mm Angle Grinder and the disc wont fit onto the Angle Grinder with Safety Guard on; well it fits on the spindle with flange nut finger tight but it can't rotate as the disc catches the lip of the safety guard.
Also, due to the depth/thickness of the disc, the angle grinder spanner pins arent long enough to reach the spindle flange nut to tighten it sufficiently.
I've used angle grinders for many years, mainly with flap disc and I've never encountered this; am I making a rookie mistake ?
I was always taught; to never use an angle grinder without a safety guard and wherever I've worked, that was the HSE rules we had to abide by.
That looks awfully close to one of them artery things. Narrow escape there I reckon.
