ned
- Eire
i was about to delete this file, so thought, it might help someone, stick it on the net.
I made the below, then printed it and stuck it to my machine with selotape.
If you are learning, and are as forgetful / dumb as me, it might be an idea to do the same.
Its in shorthand, sorry
When i say heat the metal - I mean that, if you have run 1 line of weld, the second line will go on smoother, because the base metal is now warmed up. This helps.
When i say pull it - i mean pull the rod, dont push the rod = again, better results.
the rest is self explanatory
