david.bradley
New Member
Just bought a cheap Cebora outfit on eBay.
I'm having terrible trouble.
Wire Feed, kept jamming & forming a bird nest after the wire feed motor.
I've had the head apart, & cleaned everything, fed it through gently, and seem to be getting somewhere
The wire drum fastener is homemade, just a bolt & cup washer. I find as the drum turns it tightens the bolt & eventually jams the drum fast.
If I leave it really slack, the wire unravels itself. I'm not sure what a proper fastener looks like.
Having managed 2 or 3 test runs that looked Ok, I tried to fix a patch on the car. Disaster.
I find that I cant see anything through my visor.
It's an old thing that came with an arc welder I bought 25 years ago.
It's so dark that you are just guessing what you are doing. I found I'd welded a run on top of the patch & not along the edge.
Do they darken with age, &/or do migs not need something so dark?
Finally the welder has stopped delivering any current. It hums well enough, but I cant get a spark. I've had the case off & there's no break in the wires to the earth clamp or welder head. Hard to diagnose remotely I appreciate, but any ideas please. I hadn't welded long enough to overheat, and dont know there's a thermal cut-out anyway.
Close to abandoning hope, but I'd really like to do it myself
Thanks
Thanks
