Robbie260
I fix things that others have broken
- Scotland highland
The time has come that the breaks need done on the isuzu again. Its going to cost an arm and a leg, I have some but not all the tools to do the job as I had previously done the disks on my golf. I'm going to invest in a press to help me, as my mum the spoil sport won't let me put parts in her freezer to shrink them to just drop them in when the time comes for reassembly. I'm sure a small 10 or 15 ton bench press will be perfectly adequate, with steel prices just now and lack of time I'm going to buy one. Would like it to be robust but not to heavy as will have to hump it in and out of the back of the pickup every so often. Any one got any opinions on the following.
www.craigmoreonline.co.uk
www.abcohydraulics.com
www.cromwell.co.uk
Sealey YC10B Hydraulic Press 10tonne Bench 'C' Type
High quality industrial press ideal for pressing, bending and extruding. Detachable pump and ram allow hydraulics to be used for other purposes when press is not in use. The C-frame design provides easy access to die from three sides, as well as permitting loading and unloading of wide and...
MEGA 15 Tonne Bench Mounted Press - ABCo Engineering Hydraulics
Our newly designed presses are supplied fully assembled and ready for work.
EKM | Account Cancelled | Account Closed
The online shop you were looking for has been closed. Please contact customer support on 0333 004 0333.
www.alexsuperstore.com
Kennedy Hydraulic Bench Press 10-Tonne 9855000K | Cromwell Tools
Ideal for pressing, bending and extruding. Built for tough daily use in industrial and automotive workshops. Manufactured welded steel frame with two end braces for stability and a 9855000K | Cromwell Tools
