How do I get a larger weld pool? I'm welding Kombi metal so its pretty thin and im using a gas mig with 0.6mm wire - when im spot welding the spots are really small which make it hard to bridge the gap in some areas...
Cheers
If you are spot welding through a small hole into another sheet beneath - try just moving the torch very slightly in a tiny circle to spread the pool. If you need to get more heat into the work without burning through then try backing the work with a piece of copper (some people use flattened water pipe).
Is it the metal they make Kombis from ? (VW camper)
If you are welding through one panel into another you should try a bit bigger hole in the front panel and there should not be a gap between the panels you need the panels tight together.
