Sphinx
Hi guys, I've been doing a bit more welding lately and I've come accross a couple of things I'd like to question you more experienced welders about.
Using the thin metal technique, or any other 'pulse' type system for that matter I found that the wire was sticking to the weld pool, not badly but just enough to have to 'zap' it for a fraction of a second to get it off. So I couldn't pulse, then move, then pulse. Is this a wire feed issue?
One other thing, has anyone else experienced problems with seem sealer in panels affecting welds? I was butt welding a plate in on a car panel, all good steel but close to the edge where the original skin was folded over. When I went to weld, the heat would cause the sealer to melt and almost explode making the weld spatter all over the place.
I'm not talking about a bit blob of sealer either, just the small amount that is left between the surfaces right inside the fold. I know there's no 'solution' to this, just wondered if anyone else has ever experienced this?
Thanks
Thanks
