Wightsparks
- Wight
Need to make a 4-5mm wide slot/cut, about 10mm long across 5mm x 25mm mild steel bar.
Which is easy for a one off but I need to do it 160 times (both ends of 80x 500mm bars)
My TCT is 1.7mm and two cuts is 320 cuts! Widest cutting disk I can find is 3mm, a grinding disk is very hard work.
I could cut a V shape 10mm deep - but again 320 cuts and not exactly fast also depth needs to be consistent. Basically don't want to spend hours on it if I can avoid it.
Any ideas please? Thanks!
