interesting but when will it get into production is the problem maybe 10 years ??
It's not really burning twice, it's a double expansion engine. I would have thought that would cause excessive back pressure in the primary chamber looking at the video, but it would open up the exciting possibility of throwing clean fuel and air at the secondary chamber for a burst of power when needed, much like the double expansion steam engines where you could throw a lever and dump high pressure steam into the larger secondary expansion chamber effectively doubling power. They don't seem to have thought about that possibility though...yet.
Interesting concept, until one of the big oil company's buy the patent and put it in a vault some ware.
Its crazy, these new internal combustion engines won't take off, you mark my words.
Give us a chance, I haven't worked out all the details, it was more a thinking out loud interesting possibility thing! I can't see how you can run an engine with that much back pressure.Hi, I'm not sure about introducing fresh air and fuel into the secondary chamber for more power. It works on a steam engine because the extra charge of steam is at a higher pressure than is present in there already so it gives the extra boost. On this new concept it would be introducing it into a suppressive atmosphere i.e. high in CO2. When does it get compressed and when do you ignite it? If it's ignited when the secondary piston is at the top of its stroke, which would be best so it helps push it down, the primary piston is on its way up pushing its exhaust gases into the secondary cylinder, so it would meet resistance and sap power.
Because the engine is working the air and fuel twice it would need a much larger turbo to be effective. For me this raises more questions than answers.
Colin
