Only a 10 degree bend so even if it does deform the sides slightly not the end of the worldI think it'll just deform with a break type bender. You need something with a mandrel / die to keep the box as square as it can be.
Often when box is used in like bed frames etc they deliberately deform the inside and outside of the bend leaving the sides flat.
I am on a call out so don’t have it with me but if you get a product manual from a steel stockholder they tend to have that in there.
I have books but pdf is probably somewhere.
Just Google their names
Barclay and Mathieson
Barrett Steels
Kloeckner
I use
Edit. Quick search while I’m eating - you want p38?
Page 88 sorry.I did actually find that exact chart when i was googling to see if i could find a answer before posting a thread on here
But after staring at that chart for about 5 minutes i came to the conclusion i didn't have a clue what it all meant
If it is intended to bend the 40x40x3 SHS supported over a span of 120mm it will be necessary to have a ram with a minimum force of 70Kn [7 imperial tons] to ensure the material has yielded and does not "spring back". The other information that has been provided regarding cutting and welding should be considered as the bent shape of the piece may not be as required. Good luck.
