gasket999
getting there...
- Manchester, UK
Hi folks.
I have a job that will not lend itself to a welded repair and is an ideal candidate for a panel bond adhesive. An aluminium patch on classic car - which needs a continuous seam (so spots won't do) and it would take a particularly skilled Tig welder and machine to do the job - I don't have access to either.
A little research points directly towards 3M's 8115 Panel Bond adhesive which looks to be an extremely impressive product with good reviews from insurers, OEM, Nascar and hot/street rod builders.
I'm having a little difficulty getting hold of it in the UK as 3M UK don't carry it in stock. I've found the odd supplier online and there's a few tubes on eBay but the main problem is the applicator, its an odd tandem 200ml caulking gun - see here.
The best I can come up with is buying one from the US, which I could have delivered for around £55 all in. Given that that means my first tube of bonding adhesive is going to cost around £85 by the time I've got the glue and the tube, I think I should consider some alternatives.
Does anyone know of a similar, well respected panel bond which is marketed in the UK? I'd need one specific for aircraft or automotive applications that dries without shrinking and can be sanded (so no sealant-type adhesives). I'd also need the applicator if necessary. I'll be sticking aluminium to aluminium and perhaps aluminium to steel for another job if it works well.
I'm sure Loctite used to do one years ago that was used (at the time) by Aston Martin and Lotus but I can't find it. I really don;t want an ordinary Nomorenils type adhesive as it would not cut the mustard.
Any help is gratefully received.
