Well my Tevo Tornado finally came just after Christmas. So excited! First 2 or 3 prints worked fine. Been a disaster ever since!
I just wish there was a good forum like this - Facebook groups and Reddit just not the same!
They need far more tinkering than you would ever believe. Biggest problem is getting the first layer to stick. There is a sheet of red material supplied which is self adhesive and sticks to the aluminium heated bed. Works fine BUT once you get some heat there the adhesive lets go and you get big bubbles under the surface. The solution is very Heath Robinson. Place a sheet of glass over it - then use masking tape on the surface!
I am STILL getting adhesion problems. I have moved the bed as close as is possible. Tried all sorts of temps. Tried 3 different kinds of masking tape. Even sanded the tape to make it rougher!
Also the nozzle starts hitting the work after a while.
Then you have the Y axis shift - the extra weight of the glass causes extra problems. Apparently I now need to alter the stepper motor voltage as it isn't man enough!
It is driving me crazy!
