Hi All
A techie question ! Assuming all things are equal (materials, weld prep, weld quality, gas type/flow, optimum parameters etc etc) would using a 312 filler give a "stronger" weld than using, say, a more "standard" wire such as A15 ?
I suppose what I am wanting to know is will using a filler material with a higher tensile strength actually result in a joint with greater mechanical properties ?
Also if 312 does have benefits are there any other potential issues with using it on mild steel (other than obviously the increased costs) ?
I am tring to reproduce a mild steel bracket - but am looking to make it stronger than the original item. It is obviously possible to "design" it stronger (better materials,bigger, thicker, bigger fillets etc) but I wish it to look identical. I've made some very minor tweeks here and there but just wondered if a change of filler might improve it.
I don't neccessarily need to quantify the results but if the general consensus is that it will make an improvement then I'll use 312.
I would value your input !
Cheers.
Garreth
Cheers.
Garreth
