i dont have electricity in my garage so i have to run a 30m extension to it from my house ! will this be ok running a mig ? either 131en or 151en (havnt purchased yet)
It will depend on the cable you use for the extension. I would want to see a minimum of 1.5mm. That will be around 8-10mm diameter for a three core.
Ideally, install a seperate feed to the garage, even if you do it with a free plug and socket, 2.5mm twin and earth will just go in if you are careful. Clip the cable to stop it flexing as T&E is not meant for that.
If you go to an electrical wholesaler you should be able to but flex, the black rubber type insulation is recommended for outdoor use.
If you do go to a wholesaler, ask for 2.5mm² blue arctic cable, it's designed to be abused!
designed to be abused when taking 110v the insulation is soft vynil
Sean
