S SWraymond Member Messages 47 Location South west Jan 4, 2021 #1 Hey guys, I already have a 30 amp socket, what is the biggest amp welder I can run from that?
brightspark Member Messages 41,269 Location yarm stockton on tees Jan 4, 2021 #2 SWraymond said: Hey guys, I already have a 30 amp socket, what is the biggest amp welder I can run from that? Click to expand... 30 amp in all reality look up the spec plate on them and it will tell you the input amps. dont get mixed up with output
H hotponyshoes Member Messages 7,513 Location Somerset. Uk Jan 4, 2021 #3 30a or the more common 32a? Old transformer based welders, upto about 200a or so maybe. More if you don't mind messing about with them. Modern inverters should go higher but they only go up to 230a or so before they all swap over to 3phase anyway.
zzr1200 Working at 650 ft on open steel work. Messages 6,337 Location Glapwell, Chesterfield, Derbyshire, UK Jan 4, 2021 #4 330amp mig on a blue 32amp socket, as long as your supply wiring up to it...
C Cheesie Member Messages 1,240 Location Lisburn Jan 12, 2021 #5 I've welded at 210 amp with a 13 amp household socket on my lorch t220,
