AndyStobbs
- North West England
Recently bought a two post lift for the workshop. Its a 3 phase motor, so will have to equip the unit with 3 phase.
Currently I have 3ph as far as the distribution board. My plan is to also convert the compressor to 3ph at the same time - or atleast get a supply upto it in readiness, and also to add 1, perhaps 2 5 pin sockets.
Just after a little info regards what kind of stuff is out there and what rules and regs are.
Point 1, as I understand it, every 3 ph machine is required to have a dedicated supply and breaker ( no ring main as with 1ph), is this the case?
Point 2, my DB is a crabtree, and has RCBO protection on all single phase circuits. Will the 3ph aslo need RCBO's or is MCB acceptable?
Point 3, I have some 2.5mm square single's left over (from the single phase wiring). Providing current requirements are within scope of 2.5mm, can I use up these singles, and mark them with tape to indicate which phase is which? I have 100m roll of blue un-opened - can I even mark this up as a live phase?(I would like to use up what I've got laying around where possible)
Point 4, Where 5 pin sockets are concerned, do they still need isolation - given that unplugging the plug would be an isolator in itself? Are the combined sockets and isolators any advatage over separate items?
Point 5, Is plastic conduit acceptable, for un-armoured cabling?
Thanks Gents
Thanks Gents
