Is it worth the effort?
The last few I've bought through Ebay and they are generally cheaper than making them up:
https://www.ebay.co.uk/itm/3-PHASE-16AMP-32AMP-415VOLT-EXTENSION-LEADS-4-PIN-5-PIN-HOOK-UP-LEAD-HEAVY-DUTY/173613554833?ssPageName=STRK:MEBIDX:IT&var=472292057338&_trksid=p2060353.m2749.l2649
Fair enough. Although they are VAT registered and supply an invoice so I don't see the problem with purchasing via Ebay.
2.5mm is fine
I'd go with SY cable tho, much nicer and tougher while still flexible
wait... it has to be better at resisting cuts than plain old flex... it's armoured? - fair enough the armour is only thin/flexible stuff... but a mile better than none?
It has a thin s/s braid on the outside but the cable in the middle is usually pvc with a relatively thin pvc outer cover. It's resistant to cuts but is easily damaged by crushing ie driving over it or dropping a beam on it.
A good rubber cable is fairly cut resistant but has a thick rubber outer cover & it a lot more resistant to crushing loads, you can flatten it & it will spring back into shape! It will also carry higher current loads than most cables before overheating.
I worked in a food factory where the leads on the production line machinery had a very hard life. The line was changed around regularly, there were forklifts & electric pallet trucks running around & stupid operators who didn't think it was a good idea to hang cables out of the way.
We tried the sy cable, it lasted not much longer than the HAR rubber cable we were using & it took at least twice as long to replace a cable, thus losing even more expensive production time! The production manager consulted the workshop manager & they decided to go back to the rubber cable. All the fitters were glad, we all hated the sy cable!![]()
