I always find 3 phase plugs and sockets a bit stiff and fiddly. Be easier to have both machines connected and use a 3 position change over switch. L OFF R for example.Just 1 socket is all you need? Then swap the plugs to whatever you want to power - I don't see a need for any switch?
That's what I was going to do but it's not a huge amount of money for changeover switch and unless you have a plug and play inverter then you need to switch the control circuit tooJust 1 socket is all you need? Then swap the plugs to whatever you want to power - I don't see a need for any switch?
I'm sorry I don't follow - the control circuit will be more than 1 wire (Start, stop, common feed, pot...) assuming this is what you mean, so 3 phases + 1 spare doesn't make sense? Or do you mean 1 pole as an input to the drive to swap parameter sets?That's what I was going to do but it's not a huge amount of money for changeover switch and unless you have a plug and play inverter then you need to switch the control circuit too
In my case I'm switching between two ramps, all that happens is the motor runs when asked. The control is done via linking two terminals on the VFD. On my 4 post there is a microswitch on the hydraulic valve which I used to trigger the VFD. On the 2 post I'm using the contactor that origianally controlled the motor as the switch so I can use the all the original buttons on the ramp. I can run the 3 poles for the motor, link the two commons and use the 4th pole to switch between controls. That way I'm fully switchable between the two with no risk of one ramps controls operating the motor on the other ramp
Something like this would do if you wanted to switch 3 phase + 1
Rs part no 624-9223
Yes, that wasn't aimed at you, but fizzy to give him some idea of what to look for...I din't mean to quote your original post....I did mention in my orginal post that I ordered a 1-OFF-2 32A 4 pole changover switch. Cost £19 delivered
Wait one. Asked the Sam question previously and found my own solution.I wish to run my 3 phase drill and small mill off a single vfd. Does anyone do a box with a 2 position change over switch and 2 sockets or do I need to make something up?
u can of course have them both wired into the same circuit but u don't use em at the same time....
But if you put the changeover switch between the vfd and motor then split to to the second motor only one at a time will run.You can't do this if you are running a VFD unless it's a plug and play one. If you running wired directly to the motor which most are then as soon as you operate the VFD it will operate both motors so you have to be able to isolate them by either unplugging or switching and you need to isolate the control circuits too or the controls from one machine could operate the motor on a different machine.
Use a magnetic pendant for controls and move to each machine.
Obviously need to shut off the vfd between switching but no need for interlocks in a home shop.
Ah. Crossed wires. Be running 3 identical motors to my machines to simplify things further here.Absolutely, that's how I've done mine except I'm using the 4th pole to switch my trigger circuit.
My point was that Frank said you could have them both wired into the same circuit, you can't unless it's switched or the VFD will drive both motors unless that's what Frank meant IE leave one running with no load
You don't need to shut off the VFD, just need to make sure it's not running when you switch
