supercharger
New Member
Hello,
I would just like to get professional opinion on whether a 3 pass fillet weld on 1/4 inch mild steel at 130 amps, 1/16 tungsten, 1/8 A18 Filler would be acceptable for use on an automobile cross member. The fillet would only get welded on one side of the tee as the other side has no access. The weld itself is long about 20 Inches and tig is the only option. A smaller piece made from the same stock using the settings labeled above has been completed, although the piece was 12 inches long about 3 inches of the root were done with 316 SS filler due to exotic metal in the steel (recycled steel??) causing bubble with the A18 filler. Passes 2 and 3 were all done with A18 filler. The weld appears to have good penetration, coloration on the back of the plate but I cannot destructive test this piece. It was welded by a qualified tig welder but the machine that was used could only put out 130 amps and no other option is available. I was informed that due to the relatively low amps it had to be done in three passes with a very small bevel 1/16 inch.
Would you guys be happy with this?
