celly base coat ? is there such a thing ? are you sure its not polyesterI have run out of celly thinners. Will 2k thinners do for thinning some celly basecoat. It cleaned my gun out fine. It is a small job, not a car.
He doesn't say it's metalicyes chances are the 2k thinners will work for a small non important job , sometimes makes metalics go a bit like hammerite if its not compatible
as a rule you dont sand metalic bascoat as it will ruin the effect
I gave it another few coats of this celly? it smells like pineapple chunk sweets. I did not sand it . Because although matt finish and dry, I did not think it would be cured from last night in temps of 2deg. I just warmed the paint and it sprayed fine.....hopefully I have a chemical etch between coats. I will bring indoors when it stops smelling and let it cure for a few days.
http://s126.photobucket.com/user/alexbowie/media/DSC05074.jpg.htmlAll done guys. Thanks to all. My painting is so bad as it will be another 2yrs before I paint again.........so I forget mostly anything I have done. I scratched it and gave it another base coat. Went over that with the 2k clear. The finish is fine for my purpose.
I think the black basecoat may have been Acrylic all along. I may have mistakenly marked it as celly.
Only need it to be rustproof and resistant to a slight drop of petrol splash.
It is a fuel tank. http://s126.photobucket.com/user/alexbowie/media/DSC05070.jpg.html
Don't be laughing at my non concours finish!http://s126.photobucket.com/user/alexbowie/media/DSC05074.jpg.html
extensively! I used 2mm steel sheet so I could get some heat and power with the Mig. The only bits that leaked with the airline pressure and soapy bubbles were the spigots. I went over them again. Cold welding process( mig) is not the best for this eh?
You would have had a laugh at me bending the sheet into a cylinder with no heat or machinery![]()
