C czm Member Messages 85 Location UK May 30, 2017 #1 Hi there Is it Ok to use a 2K primer before applying the water based top coat?
ajlelectronics Member Messages 11,117 Location Gloucester, England May 30, 2017 #2 Of course, but an epoxy primer would be the best choice.
C czm Member Messages 85 Location UK May 30, 2017 #3 Thanks for your help. The issue I am having is with shrinkage of the primer weeks after finishing the job Are some primers less prone to shrinkage than others??
Swift&Bold Member Messages 988 Location Dan Saff! May 30, 2017 #4 If you're leaving it weeks before spraying base colour then change to epoxy.
Maxakarudy Member Messages 323 Location West Mids May 30, 2017 #5 If you sand the primer before it's fully cured, same goes with filler, then because it's still curing after you sanded it, it sinks
