bigegg
- Leeds, West Yorkshire
I need to enlarge a through hole in a piece of 25mm thick cast iron.
The hole is currently 25mm diameter and I need to open it up to 34-35mm.
It needs to be reasonably concentric and perpendicular to the face of the plate.
Easiest way would be to bore out on a lathe, but what if no lathe available?
Will a 35mm step drill follow the existing hole?
Other ideas?
It's for a hand wheel - I want to put a m20 nut in the hole.
It will take an m16 nut at the moment, so I suppose the alternative is to drill+tap the nut to m20.
Other ideas?
