Ok, just about to prep the rest of the car body prior to paint and just got 2 quick questions.
Will high build primer fill sanding scratches created from 120 grit? Or should I step up to 240 to smooth out and then use the primer
I am using a grey scotch pad to key the paint work prior to paint - the first time I have done it to good paint work so slightly uncertain on what a properly keyed surface should look like. After scothcing away the panels still seem fairly shiney and smooth but looking down the panel have lots of very fine scratches in the existing paint. Is this a adequate key or does the surface need to be keyed more (possibly a harsher grade?)
Thanks all!
Cheers
James
Thanks all!
Cheers
James
