Can anyone here educate me a bit on 2 post car lifts? Ive only ever really seen them being used, don't know a great deal about them.
Why I need to know, is I have firmly ran out of (floor) space in the bike parking shed. Ive just nicked a bit of the floorspace for a new machine, and Ive got 6 motorbikes. I don't want to get rid of any of them (3 are handbuilt by me, the other three are either rare or of great sentimental value).
I want to seperate the two sides of a two post lift, and fix each side to the walls in the parking shed (theyre concrete block) and anchor the bases into poured plinths. Then fabricate up some hoops to capture the wheels reliably and solidly and keep the bike upright without extra straps or clamps. Then I can put the two less used ones up elevated, and park two more in use underneath. Then there is ample room for two more between. I could make my own stuff out of sliding tubes and stuff, but a car ramp split apart probably is cheaper by the time you factor in lost wages taking a holiday off work to make it and would seem to fit the bill.
For this to work, both sides of the ramp have to be independantly powered so they can be split and operated seperated. Is this the case?
Also can they be locked in elevated position to release the tension on the lifting mechanism, stop it suffering the load for long periods of time.
The load will only be 250kg max + weight of wheel support forks...
