I know it wont be possible to give a full answer to this without looking at it and that i will need to get a qualified electrician to take a look at my setup, but is the wiring on a ring main usually capable of carrying 16 amps?
I would like to alter the setup in my garage to allow me to plug the welders and plasma cutter into a 16 amp circuit. I think the garage has a dedicated supply (as opposed to being part of another ring). Running extra wires from my fusebox to the garage is going to be more hassle than its worth as the fusebox is in the middle of the house and there is no easy/obvious route to the garage without major work. So, is it possible/likely that the current wiring can be used and the other relevant bits altered?
you are lucky bartenders, or stewards as we know them
