I was trying to ascertain wether or not a 12" pizza stone would fit inside it across the middle section. ill try the pie trick!
now theres an idea. i was going to cut it open yesterday evening but valentines day scuppered that. need to keep the chef happy !if your lucky cut it in half add 2" either side and that should give you enough space for the stone and also the size of pizza to go into it
not forgetting your doorway area as this can be seperatly built using angle iron
So onwards and upwards,its now turned into a garden burner as ive elected to get a 47kg instead which is wider and make a pizza oven from that, so thats the next project .So i need some 4 inch tube for the flue for the garden burner, anybody got a lead on some 4 inch steel pipe about a metre long for a flue that doesnt come in at a million dollars ?ta
lost me there mate ,on and off.!
pie yummy42?
it depends on the type of tank
measure round it divide by 3.142 and knock off a bit for the wall thickness.
mig itIll have a look. i wondered about a stainless chimney , but dont have a tig yet to weld it
