Hi fellas this is my first post on the forum! I am a total beginner, proud owner of an ESAB 145 for two days.
I am putting together a simple frame that requires 10mm rod to be welded at 90 degrees to 3mm x 25mm flat bar. I have pre drilled holes for the rods to be mounted into, and im looking for some advice on both clamping and the actual welding technique for that setup.
I bought one of those magnetic 'arrow' clamps to hold the rod at the correct angle, but unfortunately the 10mm diameter is too narrow and ended up melting the plastic innards of the clamp. Also after making a tack weld, removing the clamp moved the rod, so any chance of accuracy was scuppered! This is why I'm not sure what clamping method to use now.
With regards to the weld, what is the best method to use when welding something round to a flat bar.
Any help appreciated.
