Hi folks,
I've been given a clarke 100e welder which had a problem with the tensioner roller. I've bought from weldequip a new roller mech plus new liner,swan neck and swan neck liner. (plus new tips / wire etc)
Is there anything I need to keep an eye on when I replace these bits as I've never done this before and the manual is a bit vague ?
Edit: Took it all apart today and the only thing I'm not sure of is the fitting of the swan neck liner - should I put the rubber o ring on it first, then fit into the swan neck before fitting the swan neck to the block ? Or should the liner be fitted through the hole that the torch liner bolts into, with the swan neck and rubber ring fitted from the other side ?
Thanks,
wishbone
Thanks,
wishbone
