Hi Guys,
for the past few weeks I've been doing a TIG welding course and am finally getting the hang of it! I've been mainly welding 4mm stainless plate using a big lincoln 3 phase TIG plant but last night I brought in my little Telwin Tecnica 111 single phase inverter as it's what I'll be using at home.
Obviously there are differences, one is 4 step the other is scratch start but the biggest difference I've found is heat! The lincoln is set at 80a and the Telwin at 40a for the same weld using the same tungsten, shroud and gas flow. But the telwin is heating up the metal to far higher temps than the lincoln. So much so that I've a blister on the side of my little finger from heat that passed through my gloves.
Why is one so much hotter than the other, even though it is set to 1/2 the current??
Thanks,
Torq
Thanks,
Torq
