Spendy!It's known as a Bastard Thread.
You could always buy a set of taps
So ive been reading.Remember that the thread is not important for centring the faceplate. The register and register face are the areas that you really need to get accurate.
Solely because its a non-standard size in relation to BSW and BSF threads.Why is that? Just down to its size and awkwardness? The diameter and pitch combination is standard BSF.
But he already has pre threaded backplates to reference his plug …Trying to do a three wire measurement on nylon will likely give misleading results as it is squishy.
I have some aluminium alreadyBut he already has pre threaded backplates to reference his plug …
Use aluminium as an alternative then….a bit more £££’s
But he already has pre-threaded backplates to reference his plug …
Fortis. British clausing 100 copy.Out of interest, what lathe is it?
Videos on YouTube?Unusual, yes, but fairly straightforward to single-point 7tpi. First, you need to find the thread-form. Likely Unified, but could be Whitworth.
As per Seadog, it’s a ‘Bastard Thread’ because both UNC and Whitworth are 5 tpi for 1 3/4” diameter.
My lathe has 1 3/4” x 6tpi square threads. They are easy enough to cut. I think doubleboost has a couple of videos on making back plates - worth watching as one also shows how to put it right after getting it wrong.
