vanagon nut
Vanagon Nut
Hi all.
I might be at the limits of my Hobart Handler. Guide on lid doesn't specify beyond 1/8" steel using gas shield. By my measure, steel is a *hair* thicker than 1/8".
Am running a dedicated #12 wire 20 Amp breaker to MIG, clean ground clamp to work, Tri-mix, Hobart "Handler" 140, .030" wire.
Pretty sure that: tip angle correct, pretty close to work.
Slowing wire speed down allowed me to make a slower weave in hopes of best penetration. Is the bead in lower and RH or image too "proud" (high)?
Would going to .035" wire, lower wire speed, achieve deeper penetration? (pass more current?)
Or, do signs of heat on backside of work indicate penetration OK?
I am hesitant to start over (again) on this piece so may weld backside where I can.
Thanks for any pointers,
Neil.
Neil.
