- Birmingham
Its that high here the waters laying on top of the ground![]()
I was just thinking that, it's raining so hard here at the moment you wouldn't need a pump, an aquavac would be just as good
It's a conductivity meter, TDS means total dissolved solids - solids of what? Then it gives a reading in Ppm - parts per million. It should read conductivity, in micro Siemens if I recall, but what does that tell you?Today, this arrived from Amazon:
Now, I am not conducting some great experiment but what I would like to do is check m water doesn't have loads of contaminants in it. So far the tap water came out at 56 and bottled water at 72, this is just a comparison scale and I wouldn't imagine for one second it is measuring ppm with any sort of accuracy. The snag is 52 is the better end of the scale and 72 is heading towards the not so good end.
Would anyone care to comment?
in the pit in my garage
just pump it out if i need to use it or ok if theres a hosepipe banDo you wear waders to work on your car ?i have about 600 gallons of water storedin the pit in my garage
no but i tripped up one day and fell inDo you wear waders to work on your car ?
was sogged
it probably saved me from broken bones if i fell the full 6 foot to the bottomHave you thought of hiring it out ? Private pools are all the rage nowno but i tripped up one day and fell inwas sogged
That's called a pond......Its that high here the waters laying on top of the ground![]()
Technically I think it's probably the north sea coming homeThat's called a pond......![]()
Ah....a "Salt Pond".Technically I think it's probably the north sea coming home![]()
im actually considering one under the pathway of the garden at least its not heavy use there as its just a house pathway and it can also collect rainwater as well for the gardeni have about 600 gallons of water storedin the pit in my garage
I'd be somewhat cautious of using heavily deionised water for anything that doesn't strictly need it. The lack of ions makes the water quite reactive around aluminium and yellow metals. Our deioniser at work produces water at ~0.5uS/cm^2, equivalent to ~0.3ppm and it will happily etch ally and makes brass fittings disappear. Only stainless and plastic fittings survive long term.Thats interesting, around here we have Spotless Water: https://www.spotlesswater.co.uk/
It is that cheap I use it for everything, windscreen fluid and especially, coolant in the machines. Washing the car and anything else I can think of.
I was really shocked when I checked the tap water with a TDS meter.
When using DI, you really do have to careful what fittings you use - it will de-zinc brass, destroy aluminium if its near stainless. Its so hungry for ions. It was an expensive lesson for where I worked 30 yrs ago. Needed a complete rethink for one machine design.That I did not know.
£6.59 gadget off Amazon - is not quite laboratory stuff...![]()
What sort of numbers are you getting on your meter?
