It really doesn't need a test case, just a clued-up RPU who can be bothered.
What would make them go full lock? Can't imagine pulling them along would make them do that, or they would do it driving along.
Incorrect castor angle would do it, but it would be undriveable on it's own.
Old model Mazda 3 diesel was impossible to A frame. Even with somebody holding steering wheel it went to full lock either left or right with any forward motion. Citroen Xantia was a challenge as it needed suspension at full height for clearance which then made it unstable over 30 mph when towed. I've been pulled over by Police twice - first was due to an accident blocking road ahead and officers helped me turn around and second was on M1 with "why have you got rear fog light on ?" after electrical fault kept blowing side light fuse. Another time tow vehicle cut out on a roundabout with a Jag XJ40 in tow. Again Police helpful and weren't interested in A frame.I know 2CV's can be challenging, but there is another make of car that is the same. Maybe @CompoSimmonite can remember, it's been a while since I was involved in such games.![]()
Not heard of that before - local motor club member had a high speed towing trailer that had a wheel base longer than the car that was on it - front wheels steered, or I imagine any corner would have been interesting.maximum distance between wheel centres for two axled trailers.
I
Never had a problem A framing my MGB GT, Austin Sprite, Series III Land Rover, 200TDi Discovery, Jeep CJ5, Mahindra MM540, Morris 1000 / Minor, and many more older vehicles.Old cars with minimal castor angle and a lot of slop in the steering system usually, used to make these for a living. MGBs, landrovers, etc could be tricky, anything with recirculating steering too.
Plus newer cars with auto locking steering columns sometimes need a cutoff system installing.
I not be able to find anyone that does the plans for a Aframe if you have a set i don't mind buying them or a copy of them thanks daveI used to have a set if you dont get any joy... , I'll see if I can find them.
I'll go hunting when I get a chance, worst case I might have a set printed off I can send you, I'll never need them.I not be able to find anyone that does the plans for a Aframe if you have a set i don't mind buying them or a copy of them thanks dave
