Thanks Dave, that's helpful.RWD3M,
You only need 4 metric or 4 imperial collets for that mil which you have. I'm sure you are aware that the the Clarkson systems only need a light snugging up with the spanner .
On the other hand the ER system needs a bigger spanner than then one provided to grip properly or be tightened by a gorilla.
There are slot drills and then there are slot drills that aren't. Your new one has a centre point on the cutting end it may need to follow a 1/4" drill hole to cut properly it may also be OK .
Some slot drills have no centre on the cutting end, but if you look one blade is longer than the other, these will plunge regardless.
I wouldn't plunge bench drill style , used the fine feed and snug up all way locks things can get a little snatchy
Itll do, I find RDG better to be honest, Cutwel better qualitySooo, is there anything fundamentally wrong with the cutter I was looking at or the company from whom I was thinking of buying from?
Thanks. I have bought stuff off them before, I'll give them a try too.Itll do, I find RDG better to be honest, Cutwel better quality
I rarely use Chronos, as their dispatch times used to be hopeless. Order something, and they might dispatch it 3 days later, but I've not used them for years.
RDG were always cheap and cheerful.
Cutwel are an industrial supplier, so are more expensive, but you know what you're getting and that it'll be sent when they say they will.
Arc were always the good compromise, but sadly no longer exist.
Thanks guys, I'll give both of these a look.Chronos and RDG sell cheap tat in my opinion.
APT are far better for tooling
Thanks for this. I'll read it properly now over a coffee!According to google 764 rpm with a 1/2” cutter and mild steel. Id probably go a bit slower, but the type of tool can have an effect too.
Step 1: Find Your Surface Feet per Minute (SFM)
Step 2: Calculate Spindle Speed (RPM)
- Look up the recommended SFM for your specific workpiece material (e.g., mild steel, aluminum) in a tool catalog or machining handbook.
- Formula: RPM = (SFM × 3.82) / Diameter (in).
- Example: For mild steel (SFM = 100) with a 0.5-inch endmill: RPM = (100 × 3.82) / 0.5 = 764 RPM.
- Manual Tip: For manual machines, you can use RPM = (SFM × 4) / Diameter for a quick estimate.
Step 3: Determine Feed Per Tooth (FPT) & Chip Load
- Look up the recommended Chip Load (or Feed Per Tooth, FPT) for your tool and material in a chart.
Step 4: Calculate Feed Rate (IPM - Inches Per Minute)
- Formula: Feed Rate (IPM) = RPM × FPT (Chip Load) × Number of Teeth.
- Example: If RPM is 764, FPT is 0.005", and you have 2 teeth: IPM = 764 × 0.005 × 2 = 7.64 IPM.
Id suggest you buy an old style apprentice type book on lathe and milling!Thanks for this. I'll read it properly now over
Good idea!Id suggest you buy an old style apprentice type book on lathe and milling!
Yep I still have a couple of mine too, but got shot of all the books of big sums, as I didnt need so many door stops.I've still got all my apprentice books from the 70's including one on machining processes.
Just checked and I still have 'mathematics for electrical and telecommunication technicians' on the bookshelfYep I still have a couple of mine too, but got shot of all the books of big sums, as I didnt need so many door stops.
Ideal for any insomniac!Just checked and I still have 'mathematics for electrical and telecommunication technicians' on the bookshelf![]()
