julianf
- devon, uk
I, eventually, move the broken hydrovane here, so its close to a power feed now, and i want to have a go at bringing it back to life.
I have the service doc, but, whilst it tells you the torque settings etc i have no flow diagram, nor know the functions of the various valves.
I wondered if i may write a list of them here (direct from the manual) and if anyone can tell me what the actual function of the parts are, so as i can have a better hope of getting to the bottom of the faults?
So, the list is -
Unloader valve
Servo valve
Vacuum relief valve
Oil return valve
Safety valve (i can probably understand this one, but i include it for completeness!)
Minimum pressure valve
Thermal by-pass valve
Oil relief valve
So thats the valves. The only other unknown function part is the -
Oil Separator
Again, i have the torque data etc and the diagrams, but without knowing the function of these blocks, and how they relate to one another, im pretty lost.
Attached is the pdf manual that this list was taken from.
Thank you
So, the list is -
Unloader valve
Servo valve
Vacuum relief valve
Oil return valve
Oil relief valve
Oil Separator
Thank you
