Found this a while back looks ok
http://www.instructables.com/id/Inexpensive-Garage-Lights-From-LED-Strips/
heat and a scraperWhats do you do when they fail? How do you get the double sided tape off your ceiling etc
heat and a scraper![]()
same hereI vote tubes
if you heat shrink the leds into a tube, how will they dissipate the heat?
Agreed they run cooler than a incandescent bulb, but they still generate heat and bake without cooling.
the waterproof ones are already plastic coated![]()
I've played about with strips and was about to change the rest of the fluorescent tubes in the garage, then came across these panels;
just fit 50 watt led floodlightsHas anyone tried any of the ebay high bay fittings? I'd love some for my barn but struggle to justify £155/fitting....
