I have similar and asked a guy who I was told had the experience to answer, his answer was no timber is put in a correctly built roof if it's not needed.
Another 'expert' said braces are often put in during construction to hold while other bits are put in and once complete could be removed but often are not.
So I pondered for a long time and mine are still in place.
Bet that has not helped much![]()
Worst thing i ever did was to allow our builder to persuade me to have a truss frame roof fitted to our extension. We lost what would have been a large room or mancave & the trusses are a pain to store stuff round.
If he got a fine I doubt he would be sent to prison it would be one or the otherThere was a guy a while back who removed the bracing and his roof collapsed, IIRC he got a hefty fine and may have even been sent to prison.
Nothing stops you removing them as long as you replace the strength they add to the structureRight then there staying. It's the upstairs of my workshop and will be getting insulated soon the idea was to turn around the edges into cupboards. The buildings not quite finished yet and I was hoping they were there just to support them during construction. But I will leave them Inplace.
correct I've seen one where a gable end gave way because of no diagonal cross bracing and a heavy storm and snowNo you can't. They are there to stop the roof flexing from wind loads along the gable-to-gable direction.
It won't immediately fall down - but will be substantially weaker and could fail in heavy wind.
I just had a roof built, and that's how it was explained to me.
Layman speaking here, but I expect that "strength" is more than just the thickness of the wood - there will be (should be!) complex geometric calculations to ensure that lateral / push / pull loads are also catered for. So the angles of the wood are probably an intrinsic part of the load and bracing calculations.Nothing stops you removing them as long as you replace the strength they add to the structure
