.... I think it makes the balls slide rather than roll and produce a lot of heat.
I wonder how many people here have watch some one go mad with a grease gun , leaving a ton of grease on the nipple. But none inside as the nipple is blocked.
I particularly like when people slather grease onto a nylon bearing...
Over greasing actually pulls dirt in to bearings,
And just to confuse things further the LT77 gearbox is spec'd to use engine oil and has it's own oil pump rather than just splash lubricatedIt's entirely design dependent imo.
A CV joint is a type of bearing, they generally utilise grease - but on a Range Rover (or disco/90/110) they put the CVs in an oil bath.
Landrover produced a special swivel grease, I think it was thixotrpic, so it turned to liquid round the cv/uj 's but remained thick around the seals.
Was that the P00 grease?
Yes, use it on the brake and clutch lever pivots on the Kwacker, good stuff for where it is intended but I would not use it in a bearing unless specified to do so.Anyone use red silicon grease? My mate swears by it as its waterproof, reckons it lasts longer too.
I have read that overgreasing "frictionless" ( ball or needle) bearings will cause the balls or needles to skid round rather than rotate and in so doing destroy the tracks.
There are some bush applications that are designed to be oiled and not greased as grease dries out in the passage ways , reduces lubrication and leads to seizure - Triumph Herald king pins and Ransomes Marquis rear rollers!!
The boom pins and undercarriage on an excavator aren't high speed or precision, they spend a lot of time submerged in water and mud, if the grease is not regularly washed through then expect large repair bills. Obviously the slew bearing and any winch bearings are a different kettle of fish.
who remembers EP 140 used to be green and smell like tom cat pee used in diffs
Hi, I do. It was used in the steering boxes of RT's and RM's and other AEC vehicles at the bus company.
Colin
