Sid
Hi all,
In the past when connecting two lengths of brake pipe together I've used male fittings (all metric/DIN by the way) on the ends of my lines, and joined with a double female fitting. It works if a little bulky.
Anyway, in a pack of parts I bought a while back, there are single female fittings. They match what came off of my car. You fit it to one line with a double flare, or a female flare if you wish, and the other line has the normal male DIN fitting.
My male flare above looks bad because I over tightened it whilst trial fitting it.
So to my question. Do I make the female/double flare with the SAE die and punches? There's no DIN female flare option with my flaring tool (a decent one). I have seen one diagram when looking that says that's what you do, but it's only one diagram from one source.
So how do you do it? (As they're brake lines I'm not keen on making a daft mistake with this.)
Cheers, Simon.
Cheers, Simon.
  Long female and full threaded male if you can find them or use the joiners.
