It's 95 quid so the MOT code only gets it to 75.ishdo you know anyone with a trade acc at euros £55+ vat sometimes you can get really good promo codes
MOT25 gives you 25% off
If it is why do they list the timken bearing for it.Have you taken it apart and tried to pressed the bearing out the housing I think you might find its all one thing could be wrong tho lol
PM me the reg and the hub you need I will get you a price tomorrowIf it is why do they list the timken bearing for it.
Loads of bearings are now complete hubs
). Worked a treat, and I was able to measure the outer diameter of the bearing, the inner diameter from the axle, and the width of the bearing from the outer shell. Then a quick web search got me a new bearing, seal and circlip for a grand total of £55 delivered.Interesting. I think my problem will be worse as the forums are claiming it can't be done but John (doubleboost) checked for an aftermarket one and he can't even get one.So true, and it's not just cars, I have a little 5'x4' Daxara trailer, and due to a poor factory weld on the axle it lets in water/crud to the back of the hub bearing. So Every 2-3 years or so (the trailer gets a lot of use) the bearing needs replaced. But they don't supply a bearing, or even a bearing kit, for this model, only a new hub at £115.00 + postage.
I got fed up with this so the last time I heard the dreaded rumble I took one of the 2 old hubs I had kept from previous changes, and using John/Doubleboost's tip of running a bead of weld around the inside of the old bearing shell to shrink it to remove (the old bearing had disintegrated and the inner race fell out with a bunch of pyramid shaped ball bearings![]()
I thought fitting would be a bit hard without a press (on the to-make list), but by freezing the new bearing and heating the hub on a gas ring, the bearing just dropped straight into place with just gravity.
Tim
We don't believe those at Euros car parts will fit the S14.......we think they are for the S13.i often get a 30% code for europarts emailed to me some days.
there was one running for the weekend just gone. VIP30
proberly expired now.
Hi there,There seem to be loads in the States - http://www.ebay.com/itm/Front-Wheel-Hub-Bearing-Seals-for-Nissan-200SX-95-98-PAIR-/200645860042?fits=Make:Nissan|Model:200SX&hash=item2eb76cdaca:m:mDlPk4_V7FnaxPF7YREoPWg&vxp=mtr
Of course, the trouble is the postage.
